I just bought an iPad Pro 12.9”, the iOS version is 13.4, Roon Core is at the latest version 1.7 (build 528), Roon remote app on the iPad the same (v 1.7, build 528).
I have been reading in the past that Roon supposedly works also in a portrait mode on the large 12.9” iPad, but it doesnˋt seem to work with my configuration.
Is there any special trick to enable this, or does perhaps Roon need to update the app build first?
New model info needs to be added to the App. This is typically done in the first maintenance release of Roon after new iPads are introduced. Give it a few weeks.
Thank you for the report. We are aware of this issue and have an active ticket with the dev team regarding it. I can’t specify a timeline of when it will reach the front of the dev queue, but once it does we will take a look to see what can be done. Thanks!
