Is it me or does Roon degrade sound
I am listening to Qobuz through my LINN KLIMAX DSM using Roon as a front end.
In a controlled setting AB testing it is very clear that the Roon sound quality is significantly less than the same tracks played on the LINN KLIMAX.
I am new to the forum and not a tech guy so this may have been covered. However, to me, there is no question that Roon is having a negative impact on streaming quality.
My system is quite high-end and maybe that makes it easy to notice the difference.
I am wondering if this is an experience others are having, and if Roon has addressed this in the past.
I love The Roon interface however I can’t really use it after having heard the LINN. The LINN interface is just awful.
What is going on and why does Roon result in a change of sound quality?
Rocco
raw
Most roon users don’t have high-end systems which is why we think it sounds, groovy.
Mines crap so I don’t.
It’s you.
Well you did ask.
I have a Naim kit with Kef R. Roon is great!
Bookmarked for future use :blush:
Could you post a pic of your signal path, it’s possible it’s not “perfect”… click the blip, eg:
I don’t trust my ears, I trust my wife’s :wink:
Seems to indicate it should sound good.
I’d suggest you need to maybe spend more or power or ethernet cables?
Or maybe your just not comparing apples with apples.
What happens if someone who knows nothing about hifi listens?
They say “you spent how much?”
I didn’t know we were a clan, cool. Just confused about what our ethos is… :face_with_monocle:
No danger of that with the Linn app then
And that would be controlled blind ABX testing?
Assuming Linn’s RAAT implementation is not terribly broken (not something I would discount for a generic “audiophile” brand, but Linn usually knows what they are doing) and that you are not applying some DSP to Roon and are actually playing exact same file, there’s no rational reason it would be different, so it isn’t :slight_smile:
:popcorn: :popcorn:
So what’s our ethos?
How about ROCK AF?
And volume matched. I’ve been through the same discussion with the Naim folks and (although I didn’t measure it) am quite convinced that direct streaming on the Naim is a tiny bit higher volume than Roon (without volume leveling). One tap up on the volume button when playing though Roon and I can’t hear any difference
I think the simple answer is within the statement is says nothing about what was tested, how it was tested, and the other elements of the system configuration.
So having seen this multiple times on the forum people go into giddy mode and don’t take it seriously especially when the “high end system” is used.
Maybe the op needs to start again with more information but these threads have a habit of going pear shaped.
Really more of a mob, don’t you think?
Not sure Nicola would like you having a clan with us mere English folk ? :upside_down_face:
Although rumour has it her husband just got a high end system. :face_with_peeking_eye:
