Is it possible to replicate preferences on a second machine?
Hello, I have the server on a Mac machine at home and I also installed Roon on another machine that I have on the farm on a second system.
My question is the following. I have backups of my library on HDs of different sizes and types than those on the main server, so I cannot replicate the paths of the main and backup HDs.
I would like to know if it is possible for me to have my playlists, tags and all the preferences that I have on the main server on this second server on the farm.
O can import the files and backup from the main server, but if they are on different paths, will the second server be able to resolve this issue? What should I do? thank you!
PS: I was using ARC via AirPlay on this second system but it is simply unfeasible to maintain, every week I come here I have to delete ARC and reinstall and the first synchronization is a lottery, it can last 20 minutes or hours, in addition the phone (IPhone 14 Pro Max) gets really hot and drains the battery very quickly. I have been bringing the iPad here because with it the problem with ARC is a little less but the application still closes frequently.
I would like some help from Support .
Then you have to go to → Support and click Get Help. Official support doesn’t monitor the user discussions here in Roon Software Discussion.
