Is Roon in dialogue with Tidal regarding volume leveling? As Tidal is reorganizing their library due to the phasing out of MQA, there are many tracks that have a volume level of +0.0. This means that many tracks are unbearable to listen to, as they are recorded way too loudly. Roon’s volume leveling is one of the features I highly appreciate about Roon because it works really well. But when Tidal’s files are set to +0.0, it becomes a problem. Can’t Roon scan the tracks itself and set the volume level?
Yes. But is there a dialog ongoing after Tidal has started removing MQA. This problem is on many tracks now and escalating.
Well the answer was yes three days ago, long after Tidal started to remove MQA. As they were pleased with you providing an example, maybe more examples help
Luck and Strange album by David Gilmour has same problem.
I have two of this in Tidal, one says 0.0 and one says -5.0 with Album Leveling. (And the -5.0 does not seem to be the default value when loudness is unknown, because it stays at -5.0 even if I change this to other values in the settings).
I only see one version.
Strange, maybe region-specific. I’m in Germany FWIW
I am i Denmark
