Just spotted your post - I have already responded to a similar one elsewhere.
I have the same problem. My Chromecast (used in one of my systems) no longer works with Roon either.
Not a problem with all wifi devices though, just Chromecast. My Muso Qb (which uses Airplay) still works.
Bill_Janssen
(Wigwam wool socks now on asymmetrical isolation feet!)
22
Core is a Synology DS918+, DSM 6.2.2-24922 Update 4, Roon 1.7, build 511
Netgear Nighthawk R7000, WiFi stable
Output is Chromecast Audio, firmware 1.42.172094
The problem is that I get the initial âblurpâ when I try to play something from Roon, but then nothing. Eventually I get a Roon error on my Control device, saying âAudio device refused to switch input to Roonâ.
Bill_Janssen
23
same here
Macbook Pro RoonCore, Google Wifi Mesh, Roon 1.17 build 511, 4 Chromecast endpoints. Everything has been working flawlessly for many months now. But all of a sudden, nothing works!?
I also get the âblurpâ but is also presented with âAudio device refused to switch input to Roonâ
i have tried restarting the RoonCore, resetting all of my Chromecasts back to factory and restarting the Google Mesh Router. But no luckâŚ
Roon works fine with my pc as a endpoint and the Chromecasts works fine with Google Music and other programs.
Anyone who has a solution?
No solution that Iâve found. I cold booted everything (routers, devices, core, etc) and nothing made any difference. I also noticed (while troubleshooting) that if you disable your devices they will not re-enable again.
Bill_Janssen
26
Could also be something like an expired certificate, I suppose. No change necessary for that.
Same problem here with chromecast on JBL Playlist and Google Chromecast 3. Streaming from Google Music (android device) to both devices doesnât work either.
JBL Playlist: firmware cast 1.28.102057
Chromecast v3: firmware cast 1.42.172094
Using Roon with Linux based machine is OK (ethernet)
Well I can play Spotify through my Chromecasts from my iPhone, but not roon. Pocket Casts - a podcast app - also plays readily from the iPhone to the Chromecasts. Spotify on my Windows 10 PC does not find the Chromecasts - but it may never have done so as I never tried that before. As well, Media Monkey 5 does not locate the Chromecasts from that Windows 10 PC, but MM5 has always been very flakey about Chromecasts.
Everything should be back to normal as of about 30 minutes ago.
When Chromecast devices kick off an application, they start by loading a web page from the internet. This briefly bounces through a web page on roonlabs.com, which redirects the Chromecast back to your Roon Core to do the real work of delivering the audio/visuals.
Earlier today, we deployed a new version of the web server configuration for roonlabs.com that broke this redirection. The web developer was unaware that Chromecast devices were depending on certain aspects of the website to be working in a particular way. This is understandableâit is far outside of their day-to-day mental model. The mistake here was letting Chromecast functionality become intertwined with the website when it was developed.
Weâve rolled back that change for now, and will soon be separating this Chromecast implementation detail from the website so that the website maintainers can make routine updates without fear of breaking Roon. We will also be auditing for any other hidden dependencies like this to prevent similar incidents in the future.
Thanks for reporting this to us quickly, and we apologize for the trouble here.
Thanks for the explanation Brian. Itâs interesting to know that cast devices are just simple web clients (running Linux/Android and a stripped down version of Chrome I suppose) and they rely a lot of non-Google web servers to provide their functionality (such as the one for roonlabs.com).
I can confirm that my Google Home, Google Home Mini and Chromecasts are all working fine now.
