I have a ROON running at home (in a container) and at home everything works fine. I have the Roon client on my ipad, and when on the home wifi I have the choice of playing music to SONOS, or to “system” which allows me to listen using my headphones.
I use tailscale as a vpn and when traveling I can use this VPN to access my mediaservers at home. Eg. I use that to access my jellyfin instance to watch movies.
However when I use roon the server is seen, I see my music, but I cannot start playback to “system”, only to my sonos. Which is useless when away from home.
Why is that? Why does the option “system” disappear when I am on a VPN?
Because UDP multicast packets do not cross subnets, and that is how endpoint discovery works. If you install Tailscale on the same device that is running the core (windows, Mac, synology, but obviously not a ROCK because you can’t) this should work.
I tried that some time ago to run Remote over tailscale although local playback wasn’t my goal. I noticed similar behavior but thought that it doesn’t work due to ACLs. Had to be wrong.
Well, I think it (meaning playing to a remote on a device that is running Tailscale) will work if you have Tailscale running on the same device as your core. There are no subnets to traverse in that case. Again, never done it, but that’s my impression.
