Issue with Hi-Def Streams for JB Radio2 (ref#N1C39W)
Please can you fix the hi-def (16 & 24 bit) streams for JB Radio2 from Ontario, Canada.
Archer VR900, Roon Nucleus Rev.2
Until Roon correctly deals with flac streams containing metadata it isn’t possible to use them (it will stop after every track).
JB Radio stopped using the non-metadata flac stream.
See
Please can you explain then, how I can stream 16bit JB Radio2 on my Naim Audio NSS333.?
Presumably because Naim deals correctly with the stream - Roon doesn’t (and are aware of the issue).
Thank you, Brian. How long does Roon usually take to address these issues?
Well, this particular issue has been known for almost 5 years…
Reading the above, does not sound very encouraging on Roon fixing this. I thought Naim was bad enough, with a week loss of service with Vtuner.:frowning:
This does not sound very encouraging for Roon support. This seems to be a long outstanding problem. It should have addressed before now. Hell, Naim sorted the problem with Vtuner in a year. They just got rid of them and deal with all collation of the streams themselves.
As this has been a known and long outstanding problem, Brian. I feel Roon should give a explanation of why this has not been addressed.
So let me get this right. Roon sells you a lifetime licence product, which relies on suppliers of music ie. record companies, music streaming services and radio station streams. All is working well at the time of the purchase, of the lifetime Roon licence. :+1:
Then one the suppliers of music, suddenly changes something. So Roon, say screw you, we have your money. Why should we give a chuff, we did not change anything.
Have I missed something? :thinking:
Yeah I’ve come to the conclusion that Roon is fairly indifferent - they move at a snails pace - It would be really great to see JB radio fixed but don’t see it happening anytime soon – I just hope Radio Paradise doesn’t change anything or we’ll be stuck with 320 BPS if we’re lucky
If only, it was at snails pace ! :blush:
What I find hard to understand, is you pay a subscription for a inferior support service.
Naim Audio had a problem with Vtuner, no service and support over Xmas. What did Naim do? They took the internet radio service in house. No problemo :ok_hand:
Tick, tock, tick, tock……this is what clocks do !
Is there any update on restoring the JB Radio2 hi-def streams for my favourite radio station? :grinning_face: :crossed_fingers:t3::crossed_fingers:t3::crossed_fingers:t3:
Any update on restoring the JB Radio2 hi-def streams? :crossed_fingers:t3::crossed_fingers:t3::crossed_fingers:t3:
Hi @BrianW
Have you checked the streams for JB Radio2 recently? I was wondering, whether they had fixed the hi-def/flac streams?
Thank you.
I run a script each day which (amongst other things) checks for metadata in flac streams.
JB Radio2 still has it.
When you write “JBRadio2 still has it”. Do you mean still has the problem with running the Flac stream, for Roon?
Sorry for not being clearer. I meant it still contained metadata.
And I’ve just checked - Roon still stops at the end of every track. (I would expect Roon to inform me if they were fixing the issue.)
Thank you Brian for the quick reply.:+1:
