Issue with Marantz NR1200 Receiver and Roon Compatibility (ref#96MLP3)
Full form submission
Something else
None of the above
How do I ...?
I have a Marantz NR1200 receiver and the combination with Roon works perfect for several years. But now it seems that the Marantz NR1200 isn’t approved working with Roon. Is there a solution for this major problem?
How have you been using the Marantz with Roon previously? The same method should still be working. E.g., by AirPlay or by HDMI.
What changed is that, due to an error on Marantz‘s part, it is now showing as „uncertified“ for Roon Ready. However, this doesn’t change anything because it was never Roon Ready and never worked that way.
In the long run this may be a good thing because the glitch happened because Marantz is apparently working on Roon Ready status.
