Full form submission
· I'm having trouble with my DAC, speakers, streamer, etc.
What best describes the issue with your audio device?
When using Roon on my Denon Home 350 (Roon tested) the volume is 100 every time I start it again.
I can turn down the volume on Denon but next time it is 100 and the speaker will explode.
Use Roon over airplay because Denon is not Roon Ready and only shows up as “other units” and not as tested.
All other units works fine with Roon
Use early access software on Mac mini and the latest
Have Denon setup as it should be and it runs perfect with HEOS and airplay from IPhone without Roon.
It is only with Roon I have this problem and tried with another Roon core standard software
Have asked Denon and they do not understand what is happening and it must be a Roon issue because the speaker works fine with all other sources
It doesn’t matter if I use fixed och device volume
