Schiit Bifrost 2 connected via USB on Win10 PC that is running Roon remote
46,191 tracks
When using ASIO4ALL v2.15 (I didn’t try on earlier versions), if I close Roon remote and re-open, the only playback devices are network streamers, not even standard USB with WASAPI.
Logging out and back into Windows (not reboot) allows it to play correctly again until closed and re-opened once more.
Hi Mark, welcome! Quick question: why are you using ASIO4ALL and not WASAPI? The former is basically a wrapper on top of the latter. Roon can work with WASAPI just fine.
In that case, I don’t see how ASIO4ALL could have made any difference, as it is just another layer on top, adding complexity and potential failure points.
There’s certainly a noticeable increase in at least volume, which doesn’t necessarily mean better SQ. I’ll stick with WASAPI and just crank up the amp a bit more.
Yes, everything else being equal, louder is always perceived as better in A/B tests. I’m sure you did your due diligence, but I would go with a fixed volume in Roon and using the preamp’s volume button.
