@support, flagging for support.
Hi @Niek_Jansen ---- Thank you for the feedback and flagging us down here. In order for me to accurately evaluate what could be causing this behavior may I very kindly ask you to please provide the following information:
Please describe your network configuration / topology, as well as providing insight into any networking hardware you may be implementing. I want to have a clear understanding of how your devices are communicating and what tools are being used to make those connections possible. The more detailed you can be, the better.
Is this the only remote device you are having this issue with or are there other device experiencing the same behavior?
Furthermore, in regard to WiFi, while is is not required we do recommend using 802.11ac Wifi if possible for best performance as mentioned here by our CTO.
-Eric
From the top of my head, thereās a modem which is connected to a Fritzbox 7360 router(it also sends Wi-fi), which is connected to a networked switch, this then connects to some other appliances like a Desktop acting as Core, wired Sonos Connect as endpoint, Synology NAS serves my smallish audio collection. Iām also running a Chromecast 2nd gen and Chromecast Ultra which are used in wireless-mode, they donāt have issues by the way.
Samsung Note4, i donāt have trouble surfing the web, watching youtube Netflix etc.
Thereās not much i can do about the router do, handed out via ISP.
Thank you in advance.
Hi @Niek_Jansen ---- Thank you for the follow up and taking the time to answer my questions. Can you please verify the make and model of the network switch being used?
-Eric
About the switch its a Conceptronic 5 port gigabit ethernetswitch(CGIGA5A), also disabled my Samsung TV Wi-Fi option it should not interfere anymore i think. Thankās again.
Hey Niek ā
FWIW: I have the same ISP-provided FritzBox. Itās a fine router (still handles all routing & DHCP on my network), but I disabled Wireless as I found it weak and unreliable (I use an Airport Express for WiFi duty). Just adding my 2 ctsā¦
Hey @Niek_Jansen ā weāre happy to look into this further, but the issues youāre describing can often be traced to unreliable WiFi as @RBM mentioned, and @Eric and I have noticed a number of issues lately with these same FritzBox wireless devices.
This is not to say weāre going to leave you to resolve this on your own ā thereās absolutely more we can do to look into this issue for you, and weāll work with you until itās stable.
That said, if the issue is the Wifi, spending time on anything else isnāt going to be productive. Is there anyway you can try this on different WiFi? Another router? A friendās network with the same Note 4? Laptop + phone at a coffee shop, anything like that?
Well thereās something i find curious regarding the RoonRemote behaviour, RM seems having trouble reaching my Core which is located on my desktop, so far ivāe told you nothing new, and then thereās the Sonos native app with which i have never experienced any connection issues whatsoever. Sonos connected wired to my Fritz! by the way.
Thanks in advance Mike.
