Hi, I have the same problem as well. Just received my SMS-200 and decided to give Roon a try for 14 days. The SMS-200 is connected to my router and the output goes to my Yggdrasil (which is on). My laptop is on Windows 10 and I activated Roon through Eunhasu. I tried to look for SMS-200 under Roon > Audio to no avail. The only device detected was the HQ Player (I’m guessing it’s a default setting, since I don’t use it). I also tried searching for devices and Roon just kept loading without any success. And yes I restarted my equipments a couple of times before I gave up, frustrated.
It’s a pity as I actually wanted to give Roon a try and to decide whether I wanted to continue my membership. I hope this issue can be resolved before my trial period ends. Will try again when I have the time today.
Hi @Paul_Tan ---- Thank you for chiming in here and sharing your observations with us, both are appreciated.
Moving forward, piggy backing on Mike’s post from above, can you please provide me with the following information:
Can you provide make, model, and specs of the Win10 device hosting your Roon core.
If you know the IP address being assigned to the SMS200 from your router, can you successfully ping the device from your laptop?
My assumption (based on your description) to this question is going to be “No, I am not”, but please verify if you are using the SMS200 in "bridge"mode.
Can you please provide the make and model of the router you are implementing.
FWIW, I have not had any problems with Roon playing to my SMS200.
Roon Core is running on Linux Mint.
Roon Core and SMS200 is connected to the same switch.
A few days ago I was on SMS200 FW 3.5 and am now on the latest 3.8. Both work fine.
I know you probably have done this, but just in case - The first time you use SMS200, you have to login to the SMS from a browser and configure Roon Ready Info (i.e. the DAC options such as DOP or Native DSD) then click the play button to start it up. Once is starts, it will auto start on any reboot.
Another thing you guys can try to isolate whether is a RAAT problem or not is to stop Roon on the SMS and enable Squeezelite. Then from the Roon Client Settings->Setup, “Enable Squeezebox support”. This is for testing only, obviously you want to get it working with RAAT.
Also, make sure you are on the latest SMS FW because you see it contains Roonready 1.1.19.
You upgrade from the browser connection under System Setup.
If you are on say 3.5, the upgrade will go to 3.6 then you have to repeat until you get to 3.7 then 3.8. The upgrade does not jump straight to the latest version.
