Hi,
Anyone facing trouble using their Logitech remotes with LS50WII?
I have both the Harmony Elite and the Ultimate One. Both used to work with my previous LS50W but unfortunately neither work with the settings for the LS50WII.
MyHarmony finds the settings for both versions and the settings for LS50W work on the LS50WII for power on/of, volume up/down etc. but not for direct source selection for the HDMI and Coax (naturally as these did not exist in version one).
The settings for LS50WII do nothing for any function.
I particularly need to select Coax input for an activity. Currently I use the settings for version one, (Select Optical, 5 sec delay, Source) sequence solves the problem but is not neat and why would the normal settings not work?
Anyone had any similar experience? Any other insights?
As for Roon, I am more than happy with the LS50WII. Most probably best bang for buck in hifi. KC62 will be the next step.
Thanks a lot
Yaman
