Laptop as Remote Screen Does Not Work
1.8 Nucleus
Using laptop as the remote
00000
TEXT GOES HERE
The Screen on my laptop is vibrating. I have reinstalled multiple times and still screen is distorted. Running Microsoft Edge
TEXT GOES HERE
Hi @Keith_Medansky ,
Can you please check to see if your Graphics Drivers are up-to-date? If you have Intel drivers, you can update them through this tool:
If that does not resolve the issue can you share some screenshots of what you are seeing?
The updated drives did not help. Problem persists.
Hello @Keith_Medansky ,
Thanks for the screenshot, this appears to be the same issue as here:
Can you please try the manual driver install?
https://downloadcenter.intel.com/download/30148/Intel-Graphics-Windows-10-DCH-Drivers
I have updated drivers. I have uninstalled the drivers and reinstalled them. Still have same screen problem
We have heard from multiple users that updating their display drivers resolves this issue, strange that you are saying that it does not on your end. What is the model/manufacturer of the laptop? Can you please try to navigate to the manufacturer website and try to install updated drivers from there?
