Hello,
Here are some thoughts after few months of using roon.
I have a lifetime sub, server installed on a headless debian, running 24/7. All albums loaded, all tracks analized, etc. Everything looks pretty good, but… not really.
Even there is no activity on roon server, it consumes over 100% of 1 core almost all the time. Rare cases when I saw something bellow 60%.
As of memory used, it stays all the time at more than 70%. And I have 32 GB RAM on this machine. This is crazy!
Having a large library, full start time for my server + all other scaning things, takes arround 40-50 minutes, never count exactly, not my target to see when it finished.
Don’t know if this issue will be ever solved by roon, i.e. to have rational & decent resources allocated for things that are really performed by the app at that moment. It seams that roon server is doing something all the time, but that’s not something I asked it to do.
For an app that I’m not using all the time plus seeing this big nachine resources allocation, I’ve just decided to simply shutdown roon server when I’m not interested to listen music, through it anyway. I just start it when I need to scan some new music or want to listen music on roon.
Wondering if roon developers plan any of the followings features:
- to allow offline use with no restrictions. Max one time license check once in a while wouldn’t be this enough?? I would like to vote for this, where is the topic with this feature request?
- to select when to update the metadata or even to disable updating it at all in the background, including the 3rd party streaming services (Tidal and Qobuz). Can’t this be an option? Bringing metadata on new albums is fine, but scaning after changes is annoying.
- when the app is in standby, no client streaming through roon , simply to go really to standby, so stop caching so much data in RAM (the database is mirrored in RAM??)
- stop developing unusefull things. ARC for android is not working nice when I’m remotely, the fowarding ports is a mess (I don’t like to use upnp on my router, I manually forward the needed ports in NAT, no big deal). So for me, at least this remote impossible connection is a no-go direction. What kind of quality (or plesasure) would you get remotely and not through your dedicated audio home system?? There are other audio streaming services or can be used some saved music on mobile when traveling.
- desktop gui is nice but I’m on it just when I’m adding new albums or want to search in roon database. Would be good to see what processes/tasks are running in background, what is consumming so much CPU+RAMs. A console with logs and services running, etc would be nice, since I am on desktop anyway, right?
- in order to connect to linux server, I have to install a full server on my windows PC as remote. So other machine resources sacrified on roon altar. Well, on Windows I can simply start/stop the roon server as I wish, not a big issue though. In this respect, a web connection to my roon server can’t be implemented?
- Plus, I would preffer a web based interface, to be able to copy paste what I may need (album name, artist name, track name).
- resizing of the diaplayed page (text size + number of albums displayed) would be also nice. Again, a web remote connection, is something impossible to be done?
By the way, I discovered also that I can vote on some roon features request just for 3 times. I vote already on Discogs integration, even I don’t think this is what I would like to see (to integrate with a personal list on Discogs) - I rather preffer to use Discogs id for manual tagging purposes. Maybe I misunderstood soimething about this voting limit which sounds so weird. Why there is a vote limit at all??
On another hand, there are other things with roon that makes me happy:
- It is great I can stream 24 bits (up to 192khz) tracks to my audio system, both in stereo or multichannel
- it is also nice I can stream MQA through my streaming device and have full unfold
- it is also good I can stream dsf files (there are converted on the fly on my end-streaming device). Would be even better if also the compressed dst would be supported, even this format doesn’t support tagging
- It is good to see all the versions of on album I have - plus that I can select which one to be primary
- Moving music between different zones is nice, sometimes I am using it
Just sharing some thoughts. Hope that some of the above mentionned issues will be handled at some point, but, tbh, I have no big expectations.
