Liberty DAC feeding through SMS 200 indicates playing but no audio heard [Solved - Power Supply]
Hi,
My Confirguration is Roon Server on Windows 10 PC via Ethernet to a SOTM SMS 200 then via USB to a Mytek Liberty DAC.
I have the issue,i don’t get audio output of my Dac anymore . The Dac still indicates playing or MQA or DSD-Upsampling from Roon on the status-led, that is the strange thing.
When I connect the dac directly to the PC via USB audio output works fine.
There is an entry in the logfile which indicates an error. :
**12/09 21:12:18 Trace: [raatmanager/windows] failed to get default device HRESULT=0x80070490**
I have tried everything, deleted config files and Raat-directory, nothing helped. Do you have any idea?
Thanx
Carsten
12/09 21:12:08 Info: Starting RAATServer v1.5 (build 363) stable on windows
12/09 21:12:08 Info: [RAATServer] creating RAAT__manager
12/09 21:12:08 Info: [RAATServer]     appdata_dir  = C:\Users\Carsten\AppData\Local\RAATServer
12/09 21:12:08 Info: [RAATServer]     unique_id    = 1be7c21b-b4fd-4d67-8308-22a947cd9a82
12/09 21:12:08 Info: [RAATServer]     machine_id   = bedb1372-dbc8-905f-96c1-68982c499a8f
12/09 21:12:08 Info: [RAATServer]     machine_name = SPECTOR2
12/09 21:12:08 Info: [RAATServer]     os_version   = Windows 10
12/09 21:12:08 Info: [RAATServer]     vendor       =
12/09 21:12:08 Info: [RAATServer]     model        =
12/09 21:12:08 Info: [RAATServer]     service_id   = d7634b85-8190-470f-aa51-6cb5538dc1b9
12/09 21:12:08 Info: [RAATServer]     is_dev       = False
12/09 21:12:08 Trace: [raatmanager] starting
12/09 21:12:08 Trace: [raatmanager/windows] failed to get default device HRESULT=0x80070490
12/09 21:12:08 Trace: [raatmanager/windows] FOUND type=asio   id={FBD8E51C-6638-4867-A3C9-D0C099CC51E0} usb_id=
12/09 21:12:08 Trace: [raatmanager/windows]       name=JRiver Media Center 23         output_name=
12/09 21:12:08 Trace: [raatmanager/windows] FOUND type=asio   id={A5CF4C32-EDCC-4383-8AF4-639197FCDF26} usb_id=
12/09 21:12:08 Trace: [raatmanager/windows]       name=Mytek USB Audio                output_name=
12/09 21:12:08 Trace: [raatmanager/windows] FOUND type=asio   id={40F4F7C8-786F-49EB-8521-23CC5358D70E} usb_id=
12/09 21:12:08 Trace: [raatmanager/windows]       name=TUSBAudio ASIO Driver          output_name=
12/09 21:12:08 Trace: [raatmanager/windows] FOUND type=asio   id={BB6A7E71-7132-426F-86FF-D4EBDEB9FA18} usb_id=
12/09 21:12:08 Trace: [raatmanager/windows]       name=USB DAC ASIO                   output_name=
12/09 21:12:08 Trace: [raatmanager] initialized
12/09 21:12:08 Info: [RAATServer] running RAAT__manager
12/09 21:12:08 Trace: [raatmanager] starting discovery
12/09 21:12:08 Trace: [discovery] starting
12/09 21:12:08 Info: [discovery] [iface:10.0.0.3] multicast recv socket is bound to 0.0.0.0:9003
12/09 21:12:08 Info: [discovery] [iface:10.0.0.3] multicast send socket is bound to 0.0.0.0:53780
12/09 21:12:08 Info: [discovery] [iface:192.168.8.100] multicast recv socket is bound to 0.0.0.0:9003
12/09 21:12:08 Info: [discovery] [iface:192.168.8.100] multicast send socket is bound to 0.0.0.0:53781
12/09 21:12:08 Info: [discovery] [iface:127.0.0.1] multicast recv socket is bound to 0.0.0.0:9003
12/09 21:12:08 Info: [discovery] [iface:127.0.0.1] multicast send socket is bound to 0.0.0.0:53782
12/09 21:12:08 Info: [discovery] unicast socket is bound to 0.0.0.0:9003
12/09 21:12:08 Trace: [raatmanager] starting server
12/09 21:12:08 Info: [jsonserver] listening on port 56636
12/09 21:12:08 Trace: [raatmanager] announcing
12/09 21:12:16 Trace: [jsonserver] [127.0.0.1:56641] accepted connection
12/09 21:12:16 Trace: [jsonserver] [127.0.0.1:56641] GOT[LL] [1] {"request":"enumerate_devices","subscription_id":"0"}
12/09 21:12:16 Trace: [jsonserver] [127.0.0.1:56641] SENT [1] [nonfinal] {"status": "Success", "devices": [{"device_id": "default", "is_system_output": true, "type": "wasapi", "name": "System Output"}, {"device_id": "{FBD8E51C-6638-4867-A3C9-D0C099CC51E0}", "type": "asio", "na
12/09 21:12:16 Debug: [discovery] broadcast op is complete
12/09 21:12:18 Trace: [RAATServer] refreshing @ 10s
12/09 21:12:18 Trace: [raatmanager] announcing
12/09 21:12:26 Debug: [discovery] broadcast op is complete
12/09 21:12:30 Trace: [jsonserver] [127.0.0.1:56641] read: eof
12/09 21:12:30 Trace: [jsonserver] [127.0.0.1:56641] destroying client
I tried using the SMS200 as a DLNA Renderer with JRIVER. Same behavior, playing, but no udio-output, so it is no Roon-Issue
Carsten
Hello @Carsten_Rombach,
Thanks for contacting support regarding this issue. Can I please ask you to visit this page (http://eunhasu.local/dacinfo/) and post a screenshot of the output? It should look something like this:
bd3709a5c3dcb05d6d7cdb56fd05f4079ac70e1b_1_690x474
Thanks,
Noris
Hi Noris,
**** List of PLAYBACK Hardware Devices ****
card 0: DAC [Liberty DAC], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 004: ID 25ce:801e
Bus 003 Device 003: ID 25ce:001e
Bus 003 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
0 [DAC ]: USB-Audio - Liberty DAC
Mytek Digital Liberty DAC at usb-1c1c000.usb-1.2, high speed
Mytek Digital Liberty DAC at usb-1c1c000.usb-1.2, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Interface 1
Altset 2
Format: S16_LE
Channels: 2
Interface 1
Altset 3
Format: SPECIAL
Channels: 2
Thanx
Carsten
Thanks for posting that info, it appears to be normal output in that text. As for next steps here - I have gone ahead and enabled diagnostics mode for your account and what this action will do is next time your Core is active, a set of logs will automatically be generated and uploaded to our servers for analysis. I kindly ask for you to leave you Core powered on and connected to the network and after receiving the diagnostics from your machine I will get a case started for you with our QA team.
Thanks,
Noris
HI Noris,
i have played some Songs (quiet) and Roon ist still active.
Thank you
Carsten
Thanks for letting me know @Carsten_Rombach, I can confirm that our servers have received the diagnostics report from your machine and I have submitted them for analysis with QA. I will be sure to let you know as soon as I have some feedback for you here and appreciate your patience in the meantime.
Thanks,
Noris
Thank you, Noris.
today i want to try to go to an older Version of the eunhasu-firmware.
Carsten
I have reflashed the SMS200 with an older firmware-same result, no audio.
Funny, then i hooked on my SMSL M8A Dac to the SMS200 and Music ist playing instandly -
Mytec alone works, SMS200 works with SMSL but not with Mytek, before Mytek worked with SMS200
While i allready had the no-sound issue i reflashed Mytek and SMS and tried all possible Setting in Roon, SMS200 and Mytec-Dac for several times.
ohmymy :monkey_face:
Finaly i located what was wrong : While connecting the Mytek directly to the pc where i got audio output i used the internal smps, on my stereo i use an external lps. i hooked the Mytek to the smps and everything works.
I still wonder why the Mytek indicated to play when there was something wrong with the lps but first i have to listen a little bit.
This really didn’t look like a little devil in the analog domain, puh
Thank you Noris for your support, you can close the case
Have a nice day
Carsten
Glad that you narrowed down the issue to the smps/lps! Thanks again for contacting support and I wish you an enjoyable listening experience! :headphones:
Thanks,
Noris
