Library gone, audio devices do not show up, Tidal won't sync
Hi @support,
I have been very happy with Roon but something very strange happend this morning.
Without making any changes to my set-up, my library suddenly has disappeared. Tidal won’t synch with my library. Also Roon can’t see any of my audio devices.
I am running my Roon core (1.2 build 165) on a 2011 Mac mini (El Capitan 10.11.6)
Music is stored on a synology NAS in 4 separate folders. Total amount is around 3500 albums.
The funny thing is that under the "storage’ tab in “settings” the folders are visible and connected but a re-scan does not work.
I have re-booted my mac, my router and my Nas but this did not help.
Any idea what could have caused this?
Hoping for an easy fix :wink:
All the best,
Martijn
Hi @Martijn ----- Thank you for the report and my apologies for the troubles here. I would like to grab a set of logs from you so our developers can have a closer look at what may be going on here. I will be contacting you via PM shortly with instructions.
-Eric
