Library problem with Qobuz album
HP with i5, 16 GB, Windows 10
Netgear router, on Ethernet
150,000 tracks
Over the past 18 months I have regularly added and removed albums from my library which are from Qobuz. I was removing a single Qobuz album from my library, and received an error message, which I did not record as I did not appreciate it would be important. The Qobuz album still shows as being in my library, and if I “remove from library” it is unsuccessful. The album info shows all 17 tracks on the album, but I cannot play any track. If I go into the edit function and attempt to delete the tracks, I get a message that there are no tracks to delete. So at this point, I cannot remove the album from my library even though there are no tracks in the library; I cannot re-add the album to my library because it shows as already being there; and I cannot play the tracks on the album.
Can you show me a way out of this dilemma?
You might try going to Settings/Services and under Qobuz to a manual resync and see if that clears it up. And or reboot the RoonCore.
Rebooting the Roon Core did the trick! Thanks very much!
