I’m not seeing any issue with this station’s playback on my end. It looks like the streaming links have been changed, so it might have been an issue with the Audacy stream.
No, @BrianW updated the stream links, but the new links are still not working for me (including the MP3 link), they stop after 1-2 seconds. This is the only station that is doing this. Must be something specific to my setup, because as you say others, including you, are not having the same problem. I am not sure how to further troubleshoot …
Hi @noris, thanks for taking a closer look at this. A little frightening but also cool that you can get into our Roon Core to poke around!
I just tried all three of that station’s streams to a zone called “MB Desktop,” which is a pair of KEF LSX speakers hooked up to my desktop, but I think Roon is sending straight to the KEFs (which are hard wired to our switch, in Settings/Audio that zone shows KEF streaming to the IP address of the speakers). Same problem, stream stops after a second or two. Other radio stations (and Tidal and local music files) are fine.
