Hi, in the lumin app the dns is not configurable.
in the roon app i confugired it on 8.8.8.8
IN my opninoin it worked flawless until the laast roon update concirning the fixes with spotify connect. Mybe something went broke after this update!?
What do you think?
In Lumin app, if you scroll down on the About page, there is an option to turn off the use of Google DNS - but you should leave it on if your Tidal / Qobuz Connect work.
If you’re asking the Lumin update, there is no Roon RAAT related changes in the last several firmware. If you want, you can factory reset the Lumin in Lumin app (scroll down). After factory reset, turn off AirPlay, Spotify Connect, etc. if you don’t use these.
