· A connected audio device is not appearing in Roon
Is your RoonServer machine running MacOS 15 Sequoia or above?
· I still can't see my endpoints as available Zones.
· Ethernet
· RoonReady
· No, it does not show up there
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
Try to disable any additional networking interfaces on your RoonServer machine.
· Disabling network interfaces had no change in behavior
Check to make sure RoonReady mode is selected on the device.
· I've checked this and the issue remains
· Only one output type is affected while the other output type works as expected
· I believe Saint of Circumstance was playing, at approximately 12 noonPDT when playback just stopped, and roon asked me to select an audio source.
· Linn Klimax, connected by Cat 6
Like another post, I was almost happy to see what a general problem this is … but I’ve spent way too much time this Christmas obsessing over more roon (Mac/roon?)issues.
My Roon server is in a Nucleus, and I am running Sequoia 15.7.3 on an iMac Pro. I'm using an Eero router, andeverything, including a Linn Klimax is connected by cat6 … and until a brief power outage last night had actually been behaving adequately for a couple weeks. I assume the restarts this morning have caused whatever snafu exists between Roon and Mac OS to manifest.
I’ve tried every workaround and check I can think of, including toggling network permissions as discussed on the forum, and will just pack it in at this point, hoping a solution is forthcoming.
I’ll keep looking for answers. I’m super happy some/many? Mac users have success with the network permission workaround … just wanted to let support know that does not work with 15.7.3, at least in this environment, and hope for some help/a solution
best I can tell you is above
