System setup:
ropieee XL 2023.05.01 on a RPi4 as an endpoint. Okto DAC8 Pro connected with an INTONA galvanic isolator.
I recently did a firmware update on the DAC to V 1.5 and the same time (stupid enough) I did update ropieee XL to the latest version. What happens now is something I never observed before:
- higher level of white noise sometimes especially between the tracks or if no music plays at all.
- the noise disappears completely as soon a track starts
- between tracks and more intensively if the format changes: flickering on the display of the DAC and some funny sizzling noise. This takes until the track actually starts to play
Okto Research told me there is more like this noticed for RPi4 devices and assume it is something with ropieee. As a firmware upgrade is not possible I can only test an older version of ropieee. But this is also not possible because I did not collect the images.
By any chance - do you have any idea what this could be? What could I do?
As long as it plays the music everything is impeccable as before but this noise in between is annoying.
Kind Regards
Ronny
