Hi ,
Marantz M-CR612 is connected (“ROON tested”) via Airplay 192.168.178.74 … but
it is not possible to play music (nothing playing…), grey play icons.
Same situation with iMac Sonoma 14.1, Macbook and iPad OS 17.1.
Marantz M-CR612 / N1B latest firmware
S/No. BGW27230788876
IP 192.168.178.74
DHCP On
MAC Ethernet 000678-BDE3C8
MAC WLAN 000678-BDE3CA
All other ROON devices are applicable, can be addressed and play fine.
M-CR612 is connectable via Airplay 2 (iMac, Macbook and iPad).
@reinhard_loessner, some AirPlay 2 implementations do not allow backward compatibility with AirPlay 1. Roon, through their own code, supports only AirPlay 1-compatible systems. For example, Roon cannot play to my LG TV with AirPlay 2, but can play to my Apple TV connected to it.
Marantz may not have AirPlay 1 available in the '612. Your MacOS and iOS devices can play to it because they have AirPlay 2 (and AirPlay 1) built into the OS.
