i’m using a roon nucleus+ core with an innuous statement and asus mesh nodes. works great. B.XL.
I use Google nest wifi which double as endpoints with Roon as well.
I had the Gen 1 Google mesh system. Each node had 2 ethernet ports which can be also be used to connect the mesh by wire (I didn’t )…
I kept having trouble with one room of the house and I upgraded to the Google Nest Gen 2 mesh. Now all was well except the set I got came with only one node with ethernet ports (the node you connect to the modem). The rest had none. Initially I tried the Gin 1 node in the room with troubles and it still had troubles… I had to buy another Gen 2 node with ports (expensive).
All has been well for a while now.
