Metadata problem
Why although I have tagged my files I think correctly, Roon displays this album in this strange way:
These are the tags in common with all the tracks:
These are the tags of one of the tracks where you can see that I have used the tags WORK and PART but Roon not recognize the composition
In metadata preference I have selected “Prefer File”
Alas, WORK & PART are effective only on unidentified albums (Edit > Identify > None of those look right > None of those look right > Use Basic File Information). This issue has been reported many times…
Ok, thank you very much and sorry for the repeated issue. I’ve done as you suggested to me, because now I do not see the composer nowhere.
Go to Settings/General and try adjusting the “Show composer credits”. I suspect this has changed somewhere along the way.
Ok solved, thank’s
