Not really sure where to post this but I need to find out the minimum bios revision that I need for my nuc8i3bek. I havent found a place to download a bios for this pc in order to run rock if my bios is too low. Wondering if I am worried for nothing.
I can’t specifically answer your question, but I don’t think you need to worry about it too much. The ‘upgrade BIOS’ requirement was from much earlier hardware, and it kinda stuck in the instructions - for no good reason. If you can install ROCK, and everything seems to work, don’t worry about it.
WHEW! Thank you so much for the reply. I have been reading the forums voraciously for the past 3 weeks just trying to learn. This is a load off my mind.
Again, thank you.
