Hi there.
I want to know the products that mqa full decoder and roon tested both support?
Various NAD
Matrix Audio Mini-I pro 3
Quite many.
What’s your budget and what other features are you after? We may be able to recommend if we can narrow it down a bit.
I have two full MQA decoders: NAD M10 and the Mytek Brooklyn DAC.
Actually that is the more important question, and well done for asking it
I can also add the iFi Zen Stream now as I am testing that feeding Metallica S&M into it over MQA 96 set to Decoder and renderer and working perfectly and this is only £399, but that is only a streamer so needs something like an iFi Zen Dac 2 or anything else like that to get the best out of it (or a better Dac even better).
So depending on your budget plenty of options available
I’m looking for it near 100 dollars.
I think it would be a good alternative.Thank you.
That may be aspirational.
Bosang as @Rockhound said you may struggle at that price point.
If you don’t mind using a PC or laptop to stream you can look at the iFi Zen Dac v2 as I read last night that it can do both part’s of the unfold.
I have never used it though so I cannot confirm anything.
It’s around £150 in the UK
Not many option at that price point. Have a look at this and see if you can implement it into your setup.
There are also several other dongles like this one.
