Problem:
- (Brand New) MSB Discrete DAC: Version 2,5R / Raat SDK Version 1,1,36: On the MSB Discrete DAC Device the volume control is enabled (volume can be changed by the MSB remote and by the rotary knob next to the display)
- Roon version 1.7 build 528: In the Device Setup for the MSB Discrete DAC for “Volume Control”: Device Volume is selected (and not Fixed Volume).
Nevertheless if you try to change the volume in Roon, this is impossible and the “Volume control is Fixed” appears (so there is no volume slider appearing / the volume can not be changed through Roon). On the website of MSB (by screenshots with a volume slider present) it is mentioned that it is possible to change the Volume of the MSB through Roon but in fact it seems impossible to do so. Is this a known issue? Is there a solution?
(Resetting the default settings of the MSB Discrete DAC does not solve the problem.)
(Restarting Roon does not solve the problem.)
(Disabling and again enabling the MSB DAC does not solve the problem).
(Rebooting the MSB Discrete DAC does not solve the problem.)
