· How do I ...?
Can I use the Muse/EQ for left and right channel separately?
the question is independent from the network
· How do I ...?
The procedural equalizer is used for advanced audio control configurations like digital crossovers, custom crossfeeds, and manual room correction. It allows you to enable and configure a series of audio control steps in a preferred order, to perform matrix mixing, and to decide which steps apply to which channels.
There are seven signal processing operations available in Procedural EQ, they are: Parametric EQ, Generic IIR filter, Mute channels, Volume, Delay, Mix, and Invert phase.
You can add as many as you like and arrange them in the order of your choice.
Good day @guidoerroi !
As @Suedkiez claimed - yes, you can do that.
please go to the “Procedural EQ” and select the options you need.
If supported, your EQ will show which channel to apply the processing to.
Regards!
@Suedkiez this is brilliant! Thank you SO much for your note!!
Hello @guidoerroi
Thank you for the update. It seems the suggestion from @Suedkiez solved your inquiry. Enjoy your music!
