Hey all,
I posted this on the audio circle site recently.
I could not get into this community for a few days.
Any input would be appreciated.
Please post it here and fill out all the requested information.
am almost at wits end here. Ever since I changed internet servers, I have been having problems.
I’ll try and be as brief as possible.
My system:
–Salk Gen III Streamplayer: (can no longer get it to work, I tried Jims LINUX commands, but I cannot login with my password provided to me, Jim also looked at it, apparently it was a bad USB port).
–ROON Nucleus (I bought it after being so frustrated with the system not working, worked great after initial hookup, but suddenly stopped outputting, although if I run ROON through a controller (Imac, Iphone, the NUCLEUS plays. Also, when I have my main system running you can see the sound bars active when you click on the audio zone).
– Van Alstine Synergy 300 Amp, MK5 DAC, Vision SL Pre
– Salk songtowers, Salk surrounds and Rhytmik sub 12"
Frank VA took my DAC and they replaced the input board, cost me $250.00, I dont remember what Jim charged…
Basically what is happening is no sound from my system. Although I can see ROON is running and works fine when playing on my iMAC or Iphone).
Another confusing thing is when I go to audio settings in ROON and choose the NUCLEUS as the core, it says (Via HDMI). My NUCLEUS is connected via USB to the DAC.
I have changed the cables, all the fuses, and I hear a pop when I fire up the amp and a bit of hiss coming from the songtowers. But no music.
I am so damn frustrated. I thought the STREAMPLAYER was the culprit, because the NUCLEUS was working great for a time. Then, gone.
Apologies for the drawn out post. Im just out of procedures to try and figure this out.
I am far from being a pro audio expert, by the way.
I thank all of you for your time.
Hi @Casey_Carney,
Thanks for reaching out to us about this issue. We’re not able to see your Nucleus in our diagnostics. So I want to test if you’re having a hardware issue. Can you please connect a monitor to your nucleus via HDMI and share a picture of what you see on the screen with us?
I pasted what I could from audio circle. Thanks
Add images
