T-Link
Bluesound Vault 2 / Melco N1A
My Roon Nucleus monitors the Bluesound and the Melco for music but not any longer my iMac including my iTunes library. My ROON music library is therefore not showing most of my music files that are stored on the hard drive of my iMac. The issue started once I upgraded the OS system of the iMac to Catalina.
I appreciate your help with this. Thx.
Bor
I forgot to mention that when I try to setup a new share or folder for Roon to monitor the same error message (unexpected error) pops up.
First, let’s focus on the Bufffalo Blue drive — Is it still connected to the Nucleus? Is it externally powered or USB powered? If you connect it to a different device does it show up okay on that device?
I reconnected the Buffalo drive to the Nucleus and is seen by the Nucleus. I also connected the Melco to the network and the Nucleus sees the device as well.
I just followed the instructions giving by Roon to make the Roon Nucleus my new Roon Core instead of the iMac. As I kept the Buffalo drive now connected to the Roon Nucleus I see now all my iTunes files in the Roon library. However if I purchase new music through iTunes on my iMac the Roon Nucleus will not see the new music files. In other words my Nucleus Roon is not scanning the hard drive of my iMac for any new music even tough it is connected to the same network.
