Core on Windows 11
Music files on Synology 420+
Device: NAD C368 wirh MDC BluOS 2.1
KPN Glasverzel 1 gb
12000
The Device is Roon Ready. What does this means.
I am looking for the correct settings in Roon for this Device.
Setting for MQA, sample conversion, DSD settings etc.
Please help me with these settings.
It means that the device as Roon’s RAAT endpoint code embedded, such that you just need to plug the ethernet cable in and the Roon Core will see the device. The basic settings are pre set. However, you might want to change them based on your particular use case.
Sorry, i am a new user of Roon.
I see different signal paths.
Signal path enhanced or excelent or something else
I want play hi-res music but i dont no
now what sample conversion does when i enable that.
And under what kind of conditions should i use the filters.
Maybe is there some study material for this.
Purple is lossless meaning nothing is touching the original data
Enhanced means you done some enhancement to it, upsampling, DSP, etc
Green means you done more to the original data including downsampling, or using a lossy format.
