I got a message as follows,
Both apps are updated. It happened from yesterday.
I’m in China.
Thanks in advance.
I’m in China.
Thanks in advance.
Try rebooting.
This message is normally where you connection to Roon Cloud is bad. If simply restarting the server doesn’t fix it then do a cold restart of all the components in the network
Try
Power everything down , wait a few minutes. Then restart the router/modem , wait until the internet connection is made , green light etc , then restart the Roon server
Hi @unihope_sh,
Thanks for writing in to let us know about this issue. Try @Mike_O_Neill’s suggestion. If that doesn’t work you may want to take a look at this conversation Is Roon banned in China? - #10 by Krutsch. It’s a bit old but it looks like what VPNs work in China can change over time. So while I cannot officially endorse using a VPN with Roon it might be something to look at.
