REGULAR WIFI
BLUESOUND NODE 2i
I get a Trial account from my Laptop in Roon. I make it works with my laptop just a few. But then I get a Node 2I and I want to test Roon with it and my Tidal Account. The Node not appears as discoverable. Thank You.
Make sure this is connected to your home network and has the latest firmware installed–see the manufacturer’s guide for details.
Then, in Roon, go to Settings > Audio to confirm that the Node 2i is listed. You should see something similar to this under Roon Ready (‘Main Bedroom’ is a Bluesound Pulse Flex):
To setup TIDAL simply go to Setting > Services and add your TIDAL userid (registered email address) and password. Once signed in you may stream music to an active zone.
Thank You Martin. It seems you need a computer to configure Roon. Is there a way to do it with my phone (ios) ?
I got the app but is like its looking for devices but find nothing.
