I compared a couple of my RoonServer logs from before and after the macOS update.
Before the update, on macOS 26.6.2, my WiiM devices were connecting normally. I can see in the older log that they sometimes disconnected, but then reconnected right away.
After updating to macOS 27.0, Roon still seems to find the devices. I can see entries for my WiiM devices and CH Precision I1.
But after that, the connection attempts keep failing with:
No route to host
I also noticed the same message in the current log when Roon tries to communicate with the local network.
A few other things I checked:
macOS firewall is off
Roon has Local Network access enabled
turning Wi-Fi off and using Ethernet only did not help
Spotify can still see and play to the WiiM devices
USB audio devices in Roon still work
So I’m wondering if this could be related to the macOS 27 update rather than the network devices themselves.
I can upload the before/after logs if that would help.
I did one more test using a different Roon Server.
I installed Roon Server on an Ubuntu machine on the same network and switched to it.
On Ubuntu, all of the network audio devices appeared immediately:
CH Precision I1
WiiM Pro Receiver
second WiiM Pro Receiver
I enabled them and playback works normally.
So the same CH and WiiM devices work correctly with Roon Server on Ubuntu, using the same network.
On the Mac mini with macOS 27, Roon Server still finds the devices but fails to connect with:
No route to host
I also tested the same IP/port from Terminal on the Mac with nc, and the connection succeeds there.
So at this point, it seems possible that this is related to the Roon Server/macOS 27 environment on the Mac, rather than the network devices themselves.
Update — resolved with the macOS 27 Local Network Privacy workaround.
The issue was caused by macOS 27 blocking outbound local-network access from RoonAppliance, even though Roon was enabled under Privacy & Security → Local Network.
I ran the following command for my wired Ethernet subnet:
mjw
(You want nice, supportive? Call a damn helpline.)
7
@Iljae_Jung, in future please do not post directly in Support. Instead, please follow this link to provide the details of your case to Technical Support: Technical Support Request
Respond to the prompts there to ensure that you’ve performed basic troubleshooting and to ensure Technical Support has the full details necessary to expedite Technical Support’s investigation into the case.
Your responses will create a ticket in Roon Lab’s support tracking system and auto-generate a Community thread in the appropriate section.
Because this Community thread will be in a public forum, please do not include any personal information, such as your email address, postal address or telephone number in your submission.
Thanks for the thorough review and for confirming the analysis. I added 224.0.0.0/4 alongside 192.168.0.0/24 and rebooted: sudo defaults write com.apple.network.local-network AllowedEthernetLocalNetworkAddresses -array “192.168.0.0/24” “224.0.0.0/4” Everything is working now: - Eversolo DMP-A6 connects and stays connected - It is discovered even when Roon is not running on the Galaxy - iPhone and Galaxy both appear as zones again - Devices connected to the Mac mini are all visible Also, thanks for the note on tccutil and FB14944392. That saved me some time. I’ll keep the exemption in place for now. Once a Roon update addresses the RoonAppliance attribution issue, I’m happy to remove the exemption and report back whether it works without it.
Glad you got there, and thank you for the Ubuntu test. Proving the same endpoints worked from a different server on the same network is what ruled out the devices and the network, and that is the part most reports are missing.
