please point me to where this setting is I have opened the Roon app gone to the settings in the app clicked on “audio” it shows “this PC” under which is the System Output, Xonar Essence ST WASAPI, Xonar WASAPI, HD Audio Device WASAPI, Xonar ASIO (64) and High Definition Audio Device WASAPI. Six total then below under Roon ready are my vault 2 and my two Sonus devices. In the settings tab for those 6 outputs there is no place to choose or turn off “exclusive mode”
You should be able to disable Exclusive Mode for certain devices so that you can play audio from your PC and Roon at the same time. We have information about this here:
If you’re unsure, you can share some screenshot of Device Setup for a device and we’d be happy to take a look at your settings!
