No audio output when Spotify Connect is playing - Roopieee on a PecanPi+ - XLR Output
I’m using a PecanPi+ which is a pi Based Streamer/DAC. My Tidal into Roon works great out of the devices analog outputs, in my case XLR. But when I try and use Spotify connect to the device, it appears as if my playback is going but I’m hearing no sound output at all from Spotify Connect.
I don’t think it’s relevant but I’ve rebooted my Roon Server. I also rebooted my PecanPi+ device multiple times. In Roopieee settings: Services > Spotify Connect > I have audio output set to HAT as I’m not using USB output but rather my analog XLR output to my amp. Initial volume set to 60. On the device I’m leaving the physical volume knob cranked all the way up. The volume knob works with Roon but I’m not sure if it even does anything when using Spotify Connect. I slowly raise my my volume to 100% on the app and still I can never hear anything coming out. Just no audio playback even though it appears it’s successfully connected to Spotify connect and playing the track otherwise.
I’ve logged out of all Spotify Devices. I’ve cleared my local Spotify cache on my iPhone.
I’m stumped here as to what I haven’t tried that might work at getting the audio to work. I’ve also even connected to a preamp just to make sure its not somehow a low audio output problem, and still nothing.
Any ideas???
