first i did a shutdown, an reboot, while shutdown Pre Box by unplugging USB.
After rebooting the mac mini, i started roon. Then i saw there is a new version, that i installed.
After that i did the first screenshot, you see only one pre box. (the sunflowwr stuff is from tests with the RME DAC before buying roject pre box, i would also like to get rid of it…)
In the next step, i enable the Pro Ject, and… have a look, there are two… i called one neveruse, becuase it is not working…
The good news is, that the other one is working now, i can hear music
Hi dabassgoesboomboom,
i tried what you suggested, and i found tge fault, made by myself.
I Renamed the Build in Output Device to Pre Box…or identifying it like this…
This should be the reason, why i could not delete or use it… i reworked it, now everything looks fine.
in the next miusic session i will here your playlist and give you feddback and input…Thanks for this, i love R&B and Soul, Funk…
I have to go deeper in all the roon sound possibilities, resolutions, and so on, i think i´m just at the beginning…but this takes time…
Thank you very much an have e nice boom boom weekend,
