Thank you for sharing those screenshots. You mentioned that Winamp played most of the album ok, but that there were still a couple of pauses.
Can I please ask you to try to reinstall the driver for the DAC and try using a different USB cable for the connection and see if the problem still persists afterwards? I would also try a different USB port on your PC in case that is related.
I have bought a new USB cable and used it to connect the hard drive to a different USB port. I downloaded the driver for my Teddy Pardo DAC this afternoon. I un installed and re installed Roon on my laptop.
I loaded up Roon and played some recently ripped music from my hard drive. It plays but the pauses for a couple of seconds several times during the song. I would not be able to play music to a visitor if it was like this.
I play the same music via Winamp. Same pausing.
I then hook up an old hard drive that has stood still for 2 years. Same pausing of music.
I’ve started playing music on Qobuz via Roon. One song paused and skipped to the next track. Another song on a different album played fine. Now listening to 2nd track if a different album and it sounds fine.
Yesterday I spoke to a guy at a computer repair shop. I think I might be going back…
If Winamp is displaying similar behavior, there are 3 possible sources for this issue:
The Core machine itself
The DAC itself
The drivers for the DAC
You can verify the first aspect by trying the DAC on a different Core PC, if it exhibits the same symptoms we can move on to theory #2/#3.
I would also reach out to the Teddy Pardo support team to see if they can help investigate this issue. Perhaps they have beta drivers for the DAC or are able to run some diagnostics on the DAC remotely.
