Hello there
I have no sound when I select DSD256 in the DSP settings. It works well in DSD128. I believe my setup should be power enough: I have a Mac mini 2018 and a Teac AI-503.
Is there anything I should do in the settings?
Hello there
On the mac mini you will only be able to do dsd 128 unless teac supplies a driver for apple os
I don’t know the exact reason but I had a mac mini and went to a windows pc.Not positive but I think someone said to 256 dsd on a mac either need a driver or your dac would have to do dsd 512 to do dsd 256 on a mac,
It is a limitation of the DOP protocol which can only be circumvented by patching kernels or a custom written driver.
Ah thanks for letting me know. I’ll check with Teac if they can release a driver for MacOS but I hardly doubt.
There has only been 1 DAC I know of that has written a MAC OS Driver (exaSound). If you want higher res DSD, Windows is really the best option.
