I have a Nucleus acting as roon server with only the power cable and the ethernet cable attached to it.
Then, i use an Esoteric Streaming dac to play Tidal streaming exclusively.
I am finding strange that from my couch i can hear the Nucleus making a noise i usually relate to writing to an old HDD.
I even opened the Nucleus to confirm there is no HDD inside…and its not.
Is this normal? Where this writing noise comes from?
Do you have an older modem/router combo near by? Their capacitors and coils can sometimes sound a little like a hdd be written to when they are under load and getting hot.
With the Nucleus off, start downloading something and start streaming some thing online and see if the modem starts making a noise. Basically, make the modem do some work.
Unfortunately I have never poked around the inside of a nucleus, maybe a noisy coil or capacitor inside it? Hopefully someone from Roon sees the thread.
After your ideas, i just picked the nucleus into my kitchen with no ethernet cable attached and no other devices on the table, plugged the power cable and… the noise its still here.
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
11
It’s truly hard to imagine what could be making the noise as there ain’t a whole lot inside there…
Just to confirm, the noise is coming from the Nucleus itself? With it powered on, put your ear close to the power supply case. Is the noise coming from there?
When you moved it to the kitchen, presumably your DAC and the rest of the system was disconnected from it?
First time I’ve seen the inside of a Nucleus. I can see why they’re not cheap compared to a basic NUC. That’s some tasty looking CNC machining from a great big chunk of billet! No heat pipes either? CPU bolted right up against the chassis?
7lbs bare weight, so almost 3kg of precisely machined, beautifully anodised Aluminium. That’s artisanal engineering!
I don’t have a Nucleus but I have a NUC7i7BNB in a fanless HD Plex case and for a number of years I used as a Roon Core, although recently I have moved those duties off to an Ubuntu Server. When I was planned this move, I had the NUC next to me on my desk, both in its use running the Roon core and now running Linux, I can hear a similar noise described by the OP. Mine is like a ‘clicking’ perhaps??
Anyway, not completely relevent in terms of hardware but I have also scrutinised the insides, in case I had somehow forgotten a spinning disk in there! I hadnt!
Mine does it as well, it’s coil wine, it didn’t matter where it was placed it still did it!
Apparently some motherboards and graphics card are prone to this, it’s not harmful, some boards do and some don’t.
I did try a linear power supply from a friend and it still did it!
Mine is running 24 hours a day and does not interfere with the playback and it far away from me and can’t hear it, still pleased with it, looks nice and as some have said a nice piece of engineering.
