Arris TM1602A Modem
Ethernet cable to Netgear Nighthawk router
Ethernet over power line (Netgear) to DAC.
PS Audio DirectStream DAC
I got Roon and Qobuz a month ago with no issues but since about a week I am not able to playback any music with resolution higher than CD quality.
My internet is fast. What is the issue and how can I fix it?
Keep in mind I was able to stream Hi Rez for the first couple of weeks (Ethernet over power). the only thing I can think of is about the same time (but I dont know for sure), there was a firmware update on the PS Audio DAC streamer…
As noted in our Networking Guide, we often recommend against the use of Ethernet Over Power adapters due to performance issues we’ve seen in the past. Often times these devices are not reliable for a stable connection.
To help understand if this is where the issue lies, can you try playing this Qobuz content to System Output of your Core machine instead of the PS Audio that is connected via EoP?
Thank you for your help, I think the culprit is the Ethernet over power line because I hard wired the PS Audio to the Router and it worked. This is strange because I had no issues for a couple of weeks??
I’m glad that you were able to pinpoint the issue!
The biggest issue we tend to see with these types of networking devices is that they’re often not as reliable as a standard Ethernet connection. It might work sometimes, but others it might not. A direct Ethernet connection, on the other hand, is typically much more stable.
If possible I’d recommend continuing to use a direct Ethernet connection and if you see any issues arise from that definitely let us know, but things should work much better for you with that configuration.
