NUC8i5BEH, 8GB of RAM (2x 4GB DDR4-2400 CL17), 500GB NVMe SSD boot drive (WD Black SN770), 1TB 2.5" SATA SSD for music (Samsung 870 EVO).
My ROCK is hardwired directly into my Verizon Fios-G1100 router via ethernet. The router is hardwired into the Nokia 211 ONT (Optical Network Terminal) that Verizon supplied me with (Model number: G-211M-C).
I have a pair of KEF LSX speakers hooked up to my M1 MacBook Pro, via Aux. I also have the KEF’s connected to Roon via the network. My MacBook is how I access the core, and manage my files via the network.
1,622 Artists, 3,897 Albums, 28,609 Tracks, 25 Composers.
My NUC Rock isn’t staying on for more than 15 seconds. Any idea what’s happening?
It behaves normally at first. I power on the NUC, see on the monitor (when I have one plugged in) that the server is working. I can also go into my router’s web UI and see that the Rock is “active”. And when I access the Roon web UI everything shows to be working just fine too.
But then, after about 15 seconds, the Rock seems to shut off. The computer monitor doesn’t recognize a device is plugged in anymore, the router’s web UI shows the Rock as “inactive”, and I can not access Roon’s web UI.
Any ideas what’s happening, and how I can fix this? Thank you!
Edit: here’s a video of what’s happening NUC Rock shutting off after 15 seconds - YouTube
