Intel NUC8i5BEH, 8GB RAM running Windows 10 Professional + Roon Server.
NUC8 motherboard + Ethernet.
Chord Mojo WASAPI, USB
Bose Soundlink Mini II SE, BT
I’m using my NUC8 as a headless Roon Server. Several times per day, I suddenly lose connection to this Roon Core. When I try to check what went wrong, by connecting a monitor either over HDMI or USB-C, I will get no signal from the device and I can no longer connect to the device using Remote Desktop. The power button LED stays on, but I can no longer shut the device down normally. I have to perform a hard shutdown by pressing the power button for 15 seconds (and losing some play data in the process).
This would appear to be an issue with the NUC unit. I’ve been looking for a cause with Intel Support for several weeks now, but just about every option appears to have been exhausted. The NUC is fully up-to-date, both BIOS-, (HDMI) Firmware- and driver-wise.
I’ve done some testing and found out the issue only occurs when Roon (Server) is running. It’s hard to reproduce the exact circumstances, but the issue often occurs when I either turn on or turn off my Chord Mojo - far from always, but often. Today it also occured just when my Bose Soundlink was about to connect over Bluetooth. Sometimes, it seems to occur when Roon has been idle for a while. The device just goes dark. I’m also pretty sure the issue has never occured while Roon was playing. I also cannot reproduce the issue when a monitor connected to my NUC and turned on.
All this leads me to suspect the issue has something to do with Roon, perhaps with the way in which it communicates with audio devices.
Could you look into this?
