I heard that Nucleus linear power supply will be available later this year.
Does it mean that Roon will release new psu replacing current SMPS adapter, or new Nucleus having linear psu inside the same box/case?
possibly later this year.
It will replace the “brick”, but it will not be a new “brick”.
It’ll be a nice form factor that will sit with the existing Nucleus case aesthetically. You will be happy when you see it.
I already had a LPSU for my NUC that I use with the Nucleus, HDPlex — it is bigger and much, much heavier than the Nucleus
Do you have plan to make the linear PSU with
“Schuko” type power plug (CEE 7/3 CEE 7/4) (220v 60hz)? If not, please please please make one. Thank you
Why would you want a brick?
In fact I’m thinking about buying a Nucleus(+) soon. In this case when new linear PSU from Roon becomes available (later this year), all I have to do is just to buy the PSU only replacing default SMPS adapter. It is a some sort of fail-safe for me.
But instead if Roon plans to make new nucleus having linear PS inside the same box, then I have to reconsider the buying timing (whether it is really necessary to buy one now)
You have misunderstood me. We are not designing a new Nucleus. We are designing a powersupply that replaces JUST THE BRICK, but it wont look or be like a brick – it’ll be a new “box” that looks good when sitting with the Nucleus.
Ok, then, back to my previous question … Do the new linear PSUs you are developing come with Schuko type power plug(CEE 7/3 7/4)?
Thank you.
Any idea when this power supply is going to be available?
Still awaiting this as well. Hope it arrives before the snow.
Ditto, and I’m happy with it. Look forward to more on the Roonlabs PSU.
Will a new Roon’s LPSU be produced and sold altogether with Nucleus or it will be offered separately as an upgrade?
@danny
Hi, What is the latest on the time frame to launch the new power supply?
Personally, I would not want a fancy box since that would ultimately add significantly to the cost. A simple plain box that does the job and that can be hidden works for me.
But from the looks of what Danny says, its probably going to be far from inexpensive
Would love to know a guess on approx cost of LPS before I buy a Nucleus + since the addition of the LPS will likely improve the SQ enough to justify a N+ purchase.
Surely you only buy a Nucleus + if you need it’s added abilities. Why would you buy one simply because a LPSU is being re less?
Any news on the Nucleus+ power supply? Availability? Cost?
Still awaiting news, in the meantime my HDPlex LPS is performing admirably. What do others use?
