Any update on when the Nucleus LPS will be launched, Danny?
You are mistaken. There is no Roon branded PSU. We ran into some problems, and resolving them meant picking sides in âaudio religionâ we arenât interested in siding with.
This project has been on hold until we find partners who are willing to work with us on this â partners on both sides.
Small Green Computer are selling a LPS that they say works with the Nucleus.
I have no idea which side of the âaudio religionâ this sits on
- Linear
- no public measurements
- no listening tests
- no explanation of why it âsoundsâ good
We could easily sell you similar stuff, but not with a clear conscious.
it can range from 12-24v â but it likes 19v/65w. Less volts, more amps. More volts, less amps.
thanks for the clarification and additional information. looks like 19v/65w is optimal.
donât know about optimal, but it is what Intel ships with.
Hi, @danny,
Any plan for Roonâs own LPS to support Nucleus?
Or any recommendations for 3rd party LPS to upgrade Nucleus?
Bought a Nucleus+ recently and found this topic:)
@Kinlin_Chu @danny has responded to this previously. Currently, there is no Roon LPS for the Nucleus devices.
Some of the LPS devices that people have used are the Sbooster, Small Green Computer and Keces P8, which I use with both my switch and Roon Nucleus.
The first of these is 36W only and is not enough for i7, despite the TDP.
Thanks @Flashman, how about Teddy Pardo?
One of my friend recommended this brand as itâs famous for LPS.
I recall reading someone here using it. If it delivers the stated current without much voltage drop itâd be enough for Nucleus+ from a specification point of view.
@Kinlin_Chu I only have experience with the Keces P8. There are many good options. As @wklie suggested, be sure whatever device you get has the right specs for the Nucleus or Nucleus+.
The P8 has the advantage of optional dual output, with the secondary output that can potentially be used for a router or switch for those who care about it. Itâs higher priced though.
I use the P8 with one output for my Netgear ProSAFE GS108 switch and the other for my Nucleus. Works like a charm!
I just ordered the MCRU LPS and Roon Nucleus Plus Rev B. Will share my experience with/without the MCRU LPS. FYI: https://www.ebay.co.uk/itm/ROON-NUCLEUS-MUSIC-SERVER-AND-MCRU-LINEAR-POWER-SUPPLY-FREE-MCRU-NO-75/153718314002?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D225076%26meid%3Dd07ea5d11ed74acca5544e418c7bb2ed%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dlo%26sd%3D153718314002%26itm%3D153718314002%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A71d22a45-5df9-11ea-a4ea-74dbd180761e|parentrq%3Aa4d90b461700ada61bbc48b0ffedcd14|iid%3A1
@danny, could you provide please what current rating (at 19V) would be sufficient for a Nucleus+ rev. B? Back in Aug. 2018 you indicated 3.42A but that before the current generation i7. I am trying to decide on an LPS and the suggestions, and even Q&Aâs with manufacturers leads to confusion. thank you
I should add, I have a 2TB SSD (Samsung EVO 860) installed and normally upsample to 384k or DSD128. Would go higher on the DSD upsample but thtaâs all my DAC does.
nothing has changed⌠power required is 65w
The device wants 12-24v with 19v preferred. You can figure out amps based on your voltage: WATTS á VOLTS = AMPS
