Soooo, whatever happened to this?
If youāre asking about a Roon sold LPS, they decided not to bring this to market. There is a post somewhere about this and why they made that decision but I canāt seem to locate itā¦
Thanks. I did read where Roon said that a they could sell a more expensive LPS, but that it was not needed.
Hi Eric
An noticeable improvements with the LPS
Sean
Roonās position via @danny in a previous post is that in general, a LPS isnāt needed with a Nucleus unless youāre connecting devices directly up to the Nucleus. Although all my main endpoints are (hard wired) networked, I do use a HDMI to go directly from my Nucleus+ to my McIntosh MX160 Video Processor to play multi-channel (greater than stereo) music files. Given this, I do use a HDPlex 200W LPS with my Nucleus+ which has 2 power rails that can be set to different voltages to power a 2nd device. (Note: this unit has now been upgraded to 300W power in the same form factor if you buy a new one today).
Has anyone tried the new iFi iPower Elite with a Nucleus (Rev B)? They have a 24volt version. Just curious.
Hi Mitch,
How are you finding the MCRU LPS? I have been considering one for my Nucleus + as I connect it directly to my Cyrus Pre XR via USB. The other option people recommend is the Farad?
Love to hear your review
Clive
Hi Danny,
Iām a new user of Roon Nucleus Plus. Love it.
Can we expect the linear power supply for Nucleus coming out soon?
Cheers,
Vincent
Iām a little afraid to ask, but I am curious to know what problems an LPS for Nucleus is intended to solve. Have there been complaints about the provided ābrickā supply, apart from its appearance?
I think there are more than one reason, but the most scientific one would be:
There is a known truth that a noisy power supply can impact analog electronic components in a manner that can reduce the precision of said components that are meant to be highly precise.
I say this is a known truth, because it is a very common problem amongst scientific and engineering measurement equipment, and it can be traced back to power supplies.
If you hook up an analog electrical component (e.g. dac, amp, speakers) to the Nucleus in any way that the noise from that power supply could interfere with the precision functionality of the connected analog component, then the replacement of that noise source with one less noisy would be considered an improvement to itās operational fidelity.
Iām not saying that the power supply that ships with Nucleus is impacting any analog components. Iām also not saying that any analog components can be improved by switching power supplies.
There may be some truth in this, depending on how unshielded your analog processes are, or how poor your power supply is.
I wrote a post in as plain of English as I could explaining the difference between linear and switching power supplies here:
In that post, pay attention close attention to how a linear power supply is not always less noisy than a switching power supply. However, old customs and terminology are hard to move away from.
I will also note that an upgraded power supply is often a status symbol, which is another major reason for switching power supplies.
No. I wrote above:
We are no longer chasing after an appropriate partner in this space. If one was to pop up that was enticing enough, we could revisit.
Hi @danny. Thanks for the thoughtful reply and link to your other post on potential advantages of an LPS. It sounds like an LPS may be beneficial for those who insist on placing Nucleus in the audio rack, either connected to or near analog components.
But, does an LPS offer advantages over a SMPS if Nucleus is moved to a closet or otherwise far away from the analog components? My guess is that physical separation is more effective (takes advantage of the inverse-square law) at mitigating power supply noise, but I want to make sure Iām not missing something obvious.
One of the things I like most about Roon is the range of deployment topologies it supports. Personally, Iād rather move Core than pay hundreds for an LPS, but I can understand how others might feel differently. Itās nice to have options.
Our suggestion is always to put the Core and as much other gear as possible outside the listening area. The Nucleus is fanless to avoid fan-noise for those who insist on putting it in the same room, but itās not our recommended configuration.
Rob Watts at Chord has this to say about Linear Power Supplies:
NOT good!
dCS is another high end brand that isnāt using traditional LPS. Merging Technologies is another.
Should be a linear unit for the price of it anyway. Its a bit of a joke using a noisy SMPS unit with a super quiet computer dedicated to audio. Also SMPS are not reliable at all.
Whereās your evidence for this statement?
SMPS have been powering my HiFi components for decades. So to state their inherently unreliable is nonsense, IMO.
Are you following me, Martin? I seem to have a stalker who has an opinion on everything I say.
Hahaha!! Not all all. Iām just correcting your misinformation for the benefit of other users ![]()
So Where do we start? They are cheap they are noisy. They are ugly. They overheat and die from time to time. they are just the cheaper alternative to a good Linear full-fat power supply.
