Was planning to preorder a Nucleus One.
Is it possible that the power adapter can be used in global power settings or only specifically for US?
Any tips and suggestions will be great. Thank you!
The switching supply used with these devices is universal and will work in the EU, UK, US etc. with the correct IEC C5 (cloverleaf) power cord or plug adaptor. Typically, they are rated 100-240 V, 50-60 Hz, 19 V, 60 W.
Hi Martin, thank u for the input. Highly appreciate. Shall go ahead and order…
