After unboxing and connecting up the Nucleus plus for the first time, it does not seem to run. See attached screen shot. After pressing any other key, to continue, it says, ‘Shell’ and wont boot up. Tried switching on and off multiple times but not change. Seems like none of the on board devices are recognised?
This is an SATA based SSD, right? Not an m.2 PCIe device?
And, did you possibly disturb the m.2 drive when fiddling with the hardware? Anyway, try and reseat the m.2.
If this isn’t helping you should report the new Nucleus as DOA…
I agree totally, but find the EFI Shell message a bit confusing? Is this machine supplied with UEFI Booting enabled already?
It’s still bust obviously, but makes me wonder a bit.
If you reboot the Nucleus unit, does it show that screen immediately on the HDMI output, without pressing any keyboard keys? Or what screen does it display?
It looks like it was trying to launch the startup script in 2 seconds, does it fail to do so? Are you stuck on that screen?
