Nucleus+ Rev B Sluggish and Unresponsive Connectivity with iPad and iPhone. Is it a Motherboard Issue? (ref#T5LBCA)
Affected Product
Nucleus
Nucleus Model
Nucleus+ Rev B
Over the last several weeks, I have had issues of the nucleus plus not responding well and at times not even responding. I reset my router, reset my nucleus, and eventually came back and started responding but now, again, it is sluggish and not responding to control from my iPad or my iPhone. Is this some motherboard issue? It does show up when I use the IP address. I never really play around with the actual device. It is hooked up to a high-end Shunyata power distributor. I use an error 6 plus access point though a Nordost QNET router.
RAM & Internal Storage
8 gb Samsung internal ssd
MSB discrete dac with Roon renderer via a wire world starlight 9 platinum Ethernet. Eero6 plus access point with a Nordost Qnet router via. CAT 10 Ethernet cables
Home Network Details
Ethernet cat 10 cable. Nordost Qnet switch with euro 6 plus access point. Shunyata Denali power distributor.
How long have you been experiencing this, what are “several” weeks. Asking because the recent Roon update (starting 18 days ago) had some weird performance/reliability effects for some people. So if this started after the update, then it could be that. If it started before the update, then the whole thing sounds like a network issue to me.
Who sold you that? No such thing exists unless you are posting from the future.
If it’s a network issue it’s difficult to put the finger on a particular thing but at least for testing I would first try without the $2K „Ethernet“ cables and without whatever cat 10 cables are supposed to be.
Oh and without the magical $3K switch that according to the ad copy claims to change the data (as its supposed effects aren’t possible any other way) which can’t be a good thing.
Could also be some setting in the router.
I would say the same thing if you had regular switches and cables. In these cases it always comes down to simplify, eliminate, rebuild.
Hi gpdegala,
I wanted to check in on this thread and see if you were still having issues? If you could please reboot your Nucleus twice and let me know if your issue persists, that would be helpful.
Thanks! :+1:
